Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › temperature not working right of domestic fridge
- This topic has 47 replies, 4 voices, and was last updated 7 months, 1 week ago by
Junk Yard.
September 1, 2025 at 4:23 pm #493596
Junk Yard
Participantkwatt wrote:Those codes, on Chinese stats like that, can be misleading. Stick with the manufacturer part number or you can run into issues. And no, they are not universal in many cases.
So your saying that they are selling a universal one that they have listed/ advertised as the modal I want including the model number for mine (and many other I would imagine). Just for a cheep sale?
https://www.ukwhitegoods.co.uk/help/fix-it-yourself/refrigeration-self-help/3658-fridge-and-freezer-thermostats
Have a look at this one
https://www.ebay.co.uk/itm/226345769565
I think it lets you set the on and off temprature, but with very little info and no UK address im out of it!September 1, 2025 at 4:24 pm #493597Junk Yard
Participantelectrofix wrote:As a professional we go to the gen stat and only if the supplier says there is an alternative do we think about it
if we get the gen then we have a 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance it will be ok. With anything else the percentages drop
So that company E Spares is where you buy your stuff from?
So you are 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain its the thermostat right? Before I buy itI spent a lot of time on this fridge cutting the door panel out and fitting a plastic glass one over it you see
September 1, 2025 at 4:58 pm #493598kwatt
KeymasterThe problem with those stats is that even although the code is the same, they can physically fit differently even on the same code.
September 1, 2025 at 5:20 pm #493599electrofix
So you are 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain its the thermostat right? Before I buy itno we have dedicated wholesale suppliers. Espares is a retail company. If they say it should fit and it does not that you can push them to do something about it. That why you need to check its the right part for you model no yourself
that’s why i said “check yourself but it says it should be correct for your model”. Although I think it is probably the correct part I cannot guarantee it, that way you cant come back and blame me if it does not fit.
September 3, 2025 at 9:48 am #493600Junk Yard
Participanti got it ordered thanks, so looking forward to it arriving
September 15, 2025 at 6:55 pm #493601Junk Yard
ParticipantI recived the part thanks. But am having problem fitting it now. there is a very thin wire that has snapped on my fridge which i think the termo is supposed to attach to
September 15, 2025 at 7:49 pm #493602kwatt
KeymasterThe thermostat has a phial on it, if that gets damaged or kinked in any way, the thermostat is rendered utterly useless.
Explained here:
September 15, 2025 at 9:28 pm #493603Junk Yard
Participantkwatt wrote:The thermostat has a phial on it, if that gets damaged or kinked in any way, the thermostat is rendered utterly useless.
Explained here:
but the pipe/ phial is broken on the fridge
September 15, 2025 at 9:48 pm #493604kwatt
KeymasterIf it was, the thermostat would never have worked.
September 16, 2025 at 12:00 am #493605Junk Yard
Participantkwatt wrote:If it was, the thermostat would never have worked.
i’ll have to weight till day light to take a photo of it all, to show you what i mean
September 17, 2025 at 2:46 am #493606Junk Yard
Participantas you can see from the photos, the phill/ pipe has broken from the fridge
September 17, 2025 at 7:34 am #493607kwatt
KeymasterThe second one is tiny but if that’s been cut then it’d be rendered useless, you cannot damage that in any way.
September 18, 2025 at 11:21 pm #493608Junk Yard
Participantkwatt wrote:The second one is tiny but if that’s been cut then it’d be rendered useless, you cannot damage that in any way.
so you are saying the fridge is gone?
September 19, 2025 at 7:34 am #493609kwatt
KeymasterNo.
The thermostat that has had the phial cut is.
September 20, 2025 at 5:12 am #493610Junk Yard
Participantkwatt wrote:No.
the one I bough those has the full coil on it. Where dose the end of the pheli fit on to?
