Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › temperature not working right of domestic fridge
- This topic has 47 replies, 4 voices, and was last updated 7 months, 1 week ago by
Junk Yard.
September 20, 2025 at 7:08 am #493611
KeymasterIt goes to where the old one was.
September 20, 2025 at 9:59 am #493612Junk Yard
Participantkwatt wrote:It goes to where the old one was.
as from the photo; it goes into the fridge housing shell somewhere
September 20, 2025 at 12:40 pm #493613kwatt
KeymasterYes, you will need to track where it was and put the new one back there without kinking or breaking it.
September 20, 2025 at 10:28 pm #493614Junk Yard
Participantkwatt wrote:Yes, you will need to track where it was and put the new one back there without kinking or breaking it.
Surly most under the counter domestic fridges will be near all same will they dont. I think from that link you provided it attaches to the compressor (cant see link at the moment)
September 20, 2025 at 10:30 pm #493615Junk Yard
Participantkwatt wrote:The thermostat has a phial on it, if that gets damaged or kinked in any way, the thermostat is rendered utterly useless.
Explained here:
Then i dont know where the phili attaches to!
September 20, 2025 at 10:36 pm #493616kwatt
KeymasterNo.
The phial will go into a sleeve or holder on the rear wall close the the evaporator that may be buried in the insulation and not visible. It is important it goes to the correct position or the temperature will not be sensed correctly and you can get over-freezing or not cooling correctly if it’s incorrectly positioned.
Even on spares diagrams that position will not be shown, you should be able to site it correctly from removing the old one or, working it out onsite.
September 20, 2025 at 10:46 pm #493617Junk Yard
Participantkwatt wrote:No.
as i can not see it and it goes though a closed wall, i mean where do i start looking?
September 20, 2025 at 10:46 pm #493618kwatt
KeymasterMy first thought would be… where the old one came from.
September 22, 2025 at 3:40 pm #493619Junk Yard
ParticipantIt goes though the wall of the fridge and will not pull out!
Can i not cut the blue bit of the new one and join it to the end of the old one (as seen in photos)
Also in the last photo, is a photo of the end of the pheli from the new one. what dose the round bit do?
September 22, 2025 at 4:55 pm #493620kwatt
KeymasterYou cannot cut it or kink it in any way! If you do, it’s done and will never work as that phial is filled with a gas that expands and contracts to operate the switch in the thermostat. Hence, if you damage that phial, the thermostat is knackered.
It will come out, they are all replaceable but how easy or hard it is varies.
September 23, 2025 at 12:15 am #493621Junk Yard
Participantkwatt wrote:You cannot cut it or kink it in any way! If you do, it’s done and will never work as that phial is filled with a gas that expands and contracts to operate the switch in the thermostat. Hence, if you damage that phial, the thermostat is knackered.
But which end dose it come out? though the inside of the fridge (see photos) or other end where we dont know?
September 23, 2025 at 7:18 am #493622kwatt
KeymasterSorry I don’t know what you mean, the thermostat phial can only be fitted one way, there are no options.
September 23, 2025 at 5:32 pm #493623Junk Yard
Participanti have drilled round it and pull it out, however i can not get the new one to go in as it will only go in about 4″
September 23, 2025 at 5:34 pm #493624kwatt
KeymasterDrilling is a very, very bad idea for two reasons, if you hit a pipe the unit is scrap, cannot be repaired. If you damage insulation and moisture gets in there, the unit is scrap.
That phial should just pull out.
September 23, 2025 at 6:13 pm #493625Junk Yard
Participantthat is what I have done pulled the old pheli out, that in the new one you can see in the photo
