Home › Forums › UK Whitegoods › UK Whitegoods Software › The Fault Code Guide
- This topic has 150 replies, 25 voices, and was last updated 14 years, 1 month ago by
kwatt.
February 7, 2013 at 4:02 pm #369840
DrDill
ParticipantRe: The Fault Code Guide
I am having the same problem
Sent from my iPhone
http://www.kitchenkitsw.comFebruary 7, 2013 at 4:03 pm #369841DrDill
Keeps telling me i have exceeded the lit to restore
Help
Sent from my iPhone
http://www.kitchenkitsw.comFebruary 7, 2013 at 4:05 pm #369842DrDill
Ignore that its sorted, lokks good!
Sent from my iPhone
http://www.kitchenkitsw.comFebruary 7, 2013 at 4:40 pm #369843Martin114
Mine is working now. I just deleted everything, re-installed and restored again.
February 7, 2013 at 6:09 pm #369844iadom
ModeratorRe: The Fault Code Guide
Noticed a small glitch, in the Hotpoint WMA fault codes, when you click on a code it displays the four lights at the top of the page but these are virtually obliterated by the model name/number, superimposed over it.
Checked the Bosch ones and the light sequence on one or two of those is displayed lower on the screen, below the bar across the top.EDIT, it’s doing it on the Bosch ones as well, sometimes the lights are displayed correctly, below the bar across the top, sometimes they are along the top, obscured by the model name.
Seems to happen if you click diagnostics then return to the error codes.
Sent from my iPad using Tapatalk HDFebruary 7, 2013 at 6:27 pm #369845iadom
Sussed out how to replicate this bug.
Go to any of the Bosch or Hotpoint models and click on an error code and if it uses lights they should display clearly, BELOW the bar across the top.
Then go to any of the Hotpoint ones that have the ‘diagnostics procedures’ feature, top left. Click on this and then return to the error codes and you should then see them right at the top of the page, covered by the model name/number. If you then go back to the Bosch codes these are now also blanked out by the model name/number.
Sent from my iPad using Tapatalk HDFebruary 7, 2013 at 6:32 pm #369846Martin
All Suneep needs to do to rectify that problem is reduce the font size I would think?
February 7, 2013 at 6:36 pm #369847iadom
Don’t think it’s that simple, they all display perfectly until you click on the Diagnostics Procedures in for instance the Hotpoint WMA codes then return. After that all the light codes are at the very top, covered by the model name, not just the Hotpoint ones.
In this instance, size doesn’t matter. 😛
February 7, 2013 at 9:21 pm #369848tonyfereno
What’s the name of the fault code app in the App Store , clicked on the link and it says not available
TonyFebruary 7, 2013 at 9:24 pm #369849sudeep
KeymasterRe: The Fault Code Guide
here is the link
https://itunes.apple.com/us/app/fault-g … ?ls=1&mt=8February 7, 2013 at 9:59 pm #369850iadom
Did you manage to see that bug I mentioned Sudeep? It happens on any model that has the Diagnostic Procedure option, it then affects all other makes & models.
February 7, 2013 at 10:05 pm #369851kwatt
What device Jim as it’s working okay on my phone?
February 7, 2013 at 10:17 pm #369852sudeep
Ya Jim, I got you, just wait for the next update. Thanks the feedback.
February 7, 2013 at 10:20 pm #369853iadom
kwatt wrote:What device Jim as it’s working okay on my phone?
iPad.February 8, 2013 at 9:29 am #369854Martin
Typo……..?
