Unknown D/W
Viewing 15 posts - 1 through 15 (of 29 total)
  • #16071
    Customer just rung, faulty dishwasher, light flashes but nothing else. Built in, no name on front, model number is a DW2677, made in Germany. Local firm fitted the kitchen, cooker is a Technics ?
    Can anyone ID this machine ?
    #167416
    Dave_Conway
    Re: Unknown D/W
    It’s a Whirlpool, same codes as in the known error codes thread 🙂
    #167417
    johnmac11
    Re: Unknown D/W
    Its a Whirlpool 854567715510
    John
    #167418
    Dave_Conway
    Re: Unknown D/W
    :wave:
    #167419
    johnmac11
    Re: Unknown D/W
    Ok Dave, you can type faster then me. 😆
    John
    #167420
    Re: Unknown D/W
    Thanks guys. :tup:
    #167421
    Re: Unknown D/W
    Apparantly 1 flash, indicating NTC failure. Where is it situated, how much, how easy, anyone know part number. 🙂
    Thank you.
    #167422
    Dave_Conway
    Re: Unknown D/W
    481228268035 about £15 trade.
    It’s underneath at the front, fits in to the sump and plugs in to the PCB.
    #167423
    Re: Unknown D/W
    Thanks again, now I need to go and see just how well integrated it really is. 😥 🙂
    #167424
    Re: Unknown D/W
    hi iodom
    you dont need to remove the appliace for this component.
    remove the plynth and then remove the front bottom panel
    the NTC is in the centre towards the front and its just a push twist fit.
    bryan
    #167425
    Re: Unknown D/W
    Thanks for that tip Bryan, hows the watch catalogue coming along. 😉
    Re: Unknown D/W
    Been to this machine today, don’t think NTC is faulty. The base is full of water, had a good look inside without pulling it out and I could not see a float switch. The water level in base was above the circulation pump motor plug, no doubt this is the cause of error message. There are signs that the circ pump is leaking. Is this common, if so anyone know part number/price?
    #167427
    Dave_Conway
    Re: Unknown D/W
    It’s not unheard of 😉
    You can buy just the pump for these as long as the water hasn’t damaged the motor part, part number for the whole thing is 481236158126 or the pump only 481236018371
    #167428
    Re: Unknown D/W
    HI IADOM
    the most likely cause is the wash motor thats leaking.
    bryan
    #167429
    Re: Unknown D/W
    Thanks guys, any idea of list price of complete unit? £45.00 at Masterpart ATM.
