Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Washing Machine Tripping Electrics
- This topic has 23 replies, 7 voices, and was last updated 14 years, 1 month ago by
stuart_faust.
February 28, 2012 at 8:41 am #68152
stuart_faust
ParticipantHi i have a Hotpoint Aquarius WF541.
Its causing some some pain as when we plug it in sometimes it trips the electric for the whole house , sometimes just the downstairs sockets sometimes it allows you to have it plugged in and turn it on without tripping then after a few seconds of it starting on any form of wash it trips again.Please can anyone help or advise on where to start?
February 28, 2012 at 8:50 am #370014nigegt
ParticipantRe: Washing Machine Tripping Electrics
Start at the heater. Test if insulation reading is poor and if so replace.
Nige
February 28, 2012 at 8:54 am #370015stuart_faust
ok thanks , when you say test if insulation reading is poor , how do i do that? i have a multimeter but no clue where to start if thats what you mean?
February 28, 2012 at 8:54 am #370016clivejameson
Time to get a meter out and look for an earth fault, heater is the usual culprit but could be a number of other things.
Plug out at all times while working on it :zap:
March 3, 2012 at 11:01 am #370017stuart_faust
hi , i tried disconnecting the brown cable to the heater and it still trips. how do i test the heater with the multimeter?
there is brown , green yellow and blue terminals.March 3, 2012 at 11:20 am #370018iadom
ModeratorRe: Washing Machine Tripping Electrics
Please don’t take offence but if you don’t know how to use a multimeter or megger to do an insulation test then you REALLY should get someone who does know to have a look at it. :zap:
March 3, 2012 at 12:41 pm #370019stuart_faust
im after some basic help as im skint and cant afford to buy a new machine. or pay for an engineer. Thought that this place was for help.
March 3, 2012 at 12:48 pm #370020iadom
stuart_faust wrote: Thought that this place was for help.
It is within the rules laid down HEREa
Better skint then electrocuted. 😉March 3, 2012 at 1:21 pm #370021stuart_faust
please could you tell me how to test the heater. i have a multimeter but am not sure what terminals to test and how. should i be testing shorts across the heater?
March 3, 2012 at 1:34 pm #370022stuart_faust
i get approx 30ohms from brown to blue. can i disconnect the heater completly and turn the electrics on and see if it trips. and if it trips its not the element?
March 6, 2012 at 8:45 am #370023stuart_faust
Ive disconnected the heater element and the electrics in the house dont trip. the washing machine does not turn on at all , does this mean it should be the heater element that’s at fault?
Any help would be great?March 12, 2012 at 8:45 am #370024stuart_faust
I have replaced the heating element and the washer still trips the electrics.
Any ideas?March 12, 2012 at 8:52 am #370025Martin
stuart_faust wrote:Any ideas?
There is an issue with the moulded 13amp plugs on these machines going faulty. I would suggest you cut off and discard the plug and replace it with a decent quality 13amp plug. 🙂
.jpg)
Please ignore the 3amp (red) fuse in the illustration, you’ll need a 13amp (brown) fuse
March 12, 2012 at 8:55 am #370026stuart_faust
Ok thanks ill try that.
March 13, 2012 at 8:27 am #370027stuart_faust
Tried a new plug , trips the second i plug it in.
Any other ideas anyone?
Does anyone know if the washing machine should turn on with the heating element disconnected? -
