Washing Machine Tripping Electrics
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Washing Machine Tripping Electrics
Viewing 9 posts - 16 through 24 (of 24 total)
  • #370028
    Allsorts
    Re: Washing Machine Tripping Electrics
    I would be looking at the cable or the suppressor…
    Check for breaks in the cable either on the outside insulation or inside the plug…
    Remove the plug from the wall, remove the lid and look for damage, burnmarks or breaks on or nearby the mains supressor.
    #370029
    stuart_faust
    tried a new mains filter still trips. i can disconnect the pump or the motor and still wont trip but no power.
    Could it be the front panel now?
    #370030
    You need someone who knows how to use electrical test equipment to check out the motor.
    #370031
    stuart_faust
    Ive tried disconnecting the motor with the block and ground , like its not attached and it still wont even turn on.
    I can get the machine to plug in without tripping the electrics by disconnecting the front control panel but obviously cant turn it on.
    #370032
    iadom wrote:You need someone who knows how to use electrical test equipment to check out the motor.
    Have you done as suggested above. ❓
    #370033
    washtronics
    you need a insulation tester (meggar) this is the only way to test insulation
    #370034
    You say you are skint, but you have ‘apparently’ already tried a new heater, new plug, you also say you have tried a new mains filter but as that comes complete with a new mains cable I am somewhat confused about how you managed that. 😕
    For goodness sake, please get someone who knows what they are doing to have a look at it or at least get the motor meggered out. :rolls:
    #370035
    stuart_faust
    i got a heater for £6 off ebay working unit. i had a spare 13amp plug and a new filter cost £20. so ive spent £26 plus my time.
    If its the motor would the machine turn on if all the power lines/cables where disconnected from it?
    #370036
    stuart_faust wrote:If its the motor would the machine turn on if all the power lines/cables where disconnected from it?
    Very likely yes, but I can’t help thinking, like my colleague, that you really haven’t a clue what you’re doing or show any indication of electrical experience. The machine requires careful testing of each component in turn using an insulation tester (aka. Megger) Poking about inside is not the way forward here and I too would advise calling someone in to check out the machine for you.
    Messing with electrics is dangerous… :zap:
