Washing Machine Tripping Electrics
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Washing Machine Tripping Electrics
Viewing 15 posts - 1 through 15 (of 24 total)
  • #68152
    stuart_faust
    Hi i have a Hotpoint Aquarius WF541.
    Its causing some some pain as when we plug it in sometimes it trips the electric for the whole house , sometimes just the downstairs sockets sometimes it allows you to have it plugged in and turn it on without tripping then after a few seconds of it starting on any form of wash it trips again.
    Please can anyone help or advise on where to start?
    #370014
    nigegt
    Re: Washing Machine Tripping Electrics
    Start at the heater. Test if insulation reading is poor and if so replace.
    Nige
    #370015
    stuart_faust
    ok thanks , when you say test if insulation reading is poor , how do i do that? i have a multimeter but no clue where to start if thats what you mean?
    #370016
    clivejameson
    Time to get a meter out and look for an earth fault, heater is the usual culprit but could be a number of other things.
    Plug out at all times while working on it :zap:
    #370017
    stuart_faust
    hi , i tried disconnecting the brown cable to the heater and it still trips. how do i test the heater with the multimeter?
    there is brown , green yellow and blue terminals.
    #370018
    Please don’t take offence but if you don’t know how to use a multimeter or megger to do an insulation test then you REALLY should get someone who does know to have a look at it. :zap:
    #370019
    stuart_faust
    im after some basic help as im skint and cant afford to buy a new machine. or pay for an engineer. Thought that this place was for help.
    #370020
    stuart_faust wrote: Thought that this place was for help.
    It is within the rules laid down HEREa
    Better skint then electrocuted. 😉
    #370021
    stuart_faust
    please could you tell me how to test the heater. i have a multimeter but am not sure what terminals to test and how. should i be testing shorts across the heater?
    #370022
    stuart_faust
    i get approx 30ohms from brown to blue. can i disconnect the heater completly and turn the electrics on and see if it trips. and if it trips its not the element?
    #370023
    stuart_faust
    Ive disconnected the heater element and the electrics in the house dont trip. the washing machine does not turn on at all , does this mean it should be the heater element that’s at fault?
    Any help would be great?
    #370024
    stuart_faust
    I have replaced the heating element and the washer still trips the electrics.
    Any ideas?
    #370025
    stuart_faust wrote:Any ideas?
    There is an issue with the moulded 13amp plugs on these machines going faulty. I would suggest you cut off and discard the plug and replace it with a decent quality 13amp plug. 🙂
    Please ignore the 3amp (red) fuse in the illustration, you’ll need a 13amp (brown) fuse
    #370026
    stuart_faust
    Ok thanks ill try that.
    #370027
    stuart_faust
    Tried a new plug , trips the second i plug it in.
    Any other ideas anyone?
    Does anyone know if the washing machine should turn on with the heating element disconnected?
