whirlpool adp 4601 not heating
Home Forums Public Support Forums Help And Support Dishwasher Help Forum whirlpool adp 4601 not heating
Viewing 15 posts - 1 through 15 (of 21 total)
  • #57177
    slyp98
    hi guys , problem with this machine it starts cycle , but wont heat the water , i’ve checked element with meter seems fine , showing continuity any ideas ? thanks
    #330133
    DOCTORDOOM
    Re: whirlpool adp 4601 not heating
    possibly ntc.
    #330134
    slyp98
    thanks doc , NTC is that temp control switch ??
    #330135
    DOCTORDOOM
    not sure about your model but it’s like a black tube that twists and locks into the sump. It has a two wire plug attached to it. I’ve just ordered one for mine, not cheap, roughly around thirty quid.
    #330136
    slyp98
    had a go again today , couldnt make it go into diagnostic mode , took off front control panel and had a look at main board looks fine no visible marks or burns , machine running fine just wont heat water ?? i guess its just a case of gettin a ntc and tryin that !
    #330137
    slyp98
    ok new ntc fitted , still no heat , 3 flashes on start button led when it stops , read the fault codes and it means heater problem , heater relay on control board faulty or cabling problem , does anyone know where the heater relay is thanks
    #330138
    DOCTORDOOM
    Same here. Fitted ntc worked once and now not heating. I’ve jumped in the deep end and ordered the 70 quid pcb. Will let you know outcome. To be honest it can’t be anything else. You live and learn then another fault you’ve never seen comes along.
    #330139
    slyp98
    jaysus doc that sounds expensive now alright 30 for ntc and 70 for control board crapola , i dont think the owner of this machine is gonna be happy
    #330140
    slyp98
    ok i have had it with this dishwasher , i fitted a new control board today and nothing , works away fine but it wont heat the water , and the salt light is on also , does anyone have the correct resistance readings for the heating element thanks grrrrrrrrrrr!!
    #330141
    slyp98
    i’m still trying to find a solution to this problem , it seems the dishwasher has live current going through it when its plugged in , i have gotten a tingle when i touch the legs and it measures 12 volts ac on the meter , im thinking its leaking to earth , would that be right a component has let the current leak through it to earth ??? thanks again
    #330142
    slyp98
    ok bad earth in the socket i was using , machine not live anymore ,
    #330143
    Simon46
    Broken wire in the door?
    Unplug power before goin in
    S.
    #330144
    slyp98
    yeah poss gonna strip it down and bench test all components ……… pffffff, fingers crossed cheers s
    #330145
    Simon46
    At the bottom of door
    #330146
    slyp98
    yeah , i can see the loom coming up from the components under neath , looks fine though no chaffing ar trapped wires , i would replace the heater element but its 140 quid cant believe it just a bit o plastic housing with the flat element on one end ????p
