Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › whirlpool adp 4601 not heating
- This topic has 20 replies, 3 voices, and was last updated 15 years, 7 months ago by
slyp98.
September 11, 2010 at 2:14 pm #57177
slyp98
Participanthi guys , problem with this machine it starts cycle , but wont heat the water , i’ve checked element with meter seems fine , showing continuity any ideas ? thanks
September 13, 2010 at 10:10 am #330133DOCTORDOOM
ParticipantRe: whirlpool adp 4601 not heating
possibly ntc.
September 13, 2010 at 11:23 am #330134slyp98
thanks doc , NTC is that temp control switch ??
September 13, 2010 at 2:29 pm #330135DOCTORDOOM
not sure about your model but it’s like a black tube that twists and locks into the sump. It has a two wire plug attached to it. I’ve just ordered one for mine, not cheap, roughly around thirty quid.
September 13, 2010 at 7:44 pm #330136slyp98
had a go again today , couldnt make it go into diagnostic mode , took off front control panel and had a look at main board looks fine no visible marks or burns , machine running fine just wont heat water ?? i guess its just a case of gettin a ntc and tryin that !
September 20, 2010 at 4:43 pm #330137slyp98
ok new ntc fitted , still no heat , 3 flashes on start button led when it stops , read the fault codes and it means heater problem , heater relay on control board faulty or cabling problem , does anyone know where the heater relay is thanks
September 20, 2010 at 5:10 pm #330138DOCTORDOOM
Same here. Fitted ntc worked once and now not heating. I’ve jumped in the deep end and ordered the 70 quid pcb. Will let you know outcome. To be honest it can’t be anything else. You live and learn then another fault you’ve never seen comes along.
September 20, 2010 at 5:23 pm #330139slyp98
jaysus doc that sounds expensive now alright 30 for ntc and 70 for control board crapola , i dont think the owner of this machine is gonna be happy
September 28, 2010 at 6:48 pm #330140slyp98
ok i have had it with this dishwasher , i fitted a new control board today and nothing , works away fine but it wont heat the water , and the salt light is on also , does anyone have the correct resistance readings for the heating element thanks grrrrrrrrrrr!!
October 8, 2010 at 10:44 am #330141slyp98
i’m still trying to find a solution to this problem , it seems the dishwasher has live current going through it when its plugged in , i have gotten a tingle when i touch the legs and it measures 12 volts ac on the meter , im thinking its leaking to earth , would that be right a component has let the current leak through it to earth ??? thanks again
October 11, 2010 at 10:00 am #330142slyp98
ok bad earth in the socket i was using , machine not live anymore ,
October 11, 2010 at 10:07 am #330143Simon46
Broken wire in the door?
Unplug power before goin in
S.October 11, 2010 at 10:20 am #330144slyp98
yeah poss gonna strip it down and bench test all components ……… pffffff, fingers crossed cheers s
October 11, 2010 at 10:36 am #330145Simon46
At the bottom of door
October 11, 2010 at 12:10 pm #330146slyp98
yeah , i can see the loom coming up from the components under neath , looks fine though no chaffing ar trapped wires , i would replace the heater element but its 140 quid cant believe it just a bit o plastic housing with the flat element on one end ????
p -
