Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWM 045
- This topic has 21 replies, 5 voices, and was last updated 18 years, 9 months ago by
iadom.
July 16, 2007 at 11:41 am #29039
Moderator12 NC 8570 045 15100
Machine will do nothing other than lock the door on any programme, the mains On/Off neon does not illuminate. Motor brushes etc appear fine. No visible signs of damage on control unit.
Any pointers, cannot see any test procedures on SIOS disc. ?
July 16, 2007 at 11:53 am #221237Martin
ParticipantRe: Whirlpool AWM 045
Broken wiring harness adjacent to air chamber? Heater open circuit? Motor continuity? Are the most likely reasons as the programme module self checks all these before proceeding. 😉
July 16, 2007 at 4:38 pm #221238iadom
ModeratorRe: Whirlpool AWM 045
Did check the motor, will have a look at those other items, :tup:
Is it normal for the mains neon not to light up though?
July 21, 2007 at 9:28 am #221239iadom
Checked out every single component, changed the door lock just in case, still the same, door locks then nothing. 😕
Thinking control unit now. Unless you know different. 😉
July 21, 2007 at 10:07 am #221240Martin
iadom wrote:Is it normal for the mains neon not to light up though?
The mains neon return is via the circuit board so perhaps the board is the guilty party? 😕
Maybe JohnMac11 can confirm? 😉
July 21, 2007 at 1:19 pm #221241gegsy
Jim
You have mail 😉Greg
August 2, 2007 at 9:19 am #221242iadom
Only just got back to this one, waiting for new control unit.
The control unit is faulty, however although the mains neon now comes on and door locks it still does nothing else.After stripping down the old unit I am hoping that I have not damaged the new one. 😥
The old unit has blown, any ideas as to what may have caused this, door lock and fill valves appear to be connected in that area, no signs of any earth failure.
August 2, 2007 at 10:19 am #221243Martin
iadom wrote:The old unit has blown, any ideas as to what may have caused this
Can’t figure from the photo Jim but do you know want terminals are connected adjacent to the blown circuit? We could then run through the wiring diagram to locate the fault, maybe?
August 2, 2007 at 10:25 am #221244iadom
Difficult to say Martin, looks like pilot lamp & fill valves. 😕
Terminal numbers, VHF31,PL33, PL31 etc.
August 2, 2007 at 10:42 am #221245Martin
iadom wrote:no signs of any earth failure.
The mains switch (on/off sw) is double pole (I think?) so I wonder if it’s a polarity short? The SIOS wiring diagram is rubbish at best, so can’t fathom owt from that…..I’m just guessing otherwise Jim, sorry! 😕
August 2, 2007 at 10:49 am #221246iadom
Hopefully the Jock in exile may come up with something later. 😉
August 2, 2007 at 4:35 pm #221247johnmac11
Cant see which connector on the timer is blown. If it is the connections towards the back of the appliance it is either the mains switch, pressostat or heater/NTC.
Usualy when I come across a timer with a blown edge connector the cause is either the door lock, on/off switch or the NTC.
In the case of a blown NTC make sure you remove it from machine and check visualy, have saw some that come back with a resistance reading that is fine but a soon as water is put in machine it will blow the timer again, caused by drum dropping onto heater and slicing a nice hole through the NTC.
John
August 2, 2007 at 5:33 pm #221248iadom
No edge connectors actually damaged John, just a couple of tracks on the back of the board, one wire link( RD 11) and one resistor ( R5) plus a small triac/transistor( TC2) blown on component side. The machine is in perfect physical condition, could the drum still catch the heater?
August 2, 2007 at 7:28 pm #221249johnmac11
On all the ones I have saw that have blown tracks I would say that in 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of cases the fault was caused by either the heater/NTC or the door lock.
I have saw machines where the drum is fine but a coin has spun round with the drum and cut through the ntc (very thin metal). If the heater is cut through then the drum will more than likely have dropped onto it.
JohnAugust 2, 2007 at 9:48 pm #221250iadom
Thanks John, will let you know the outcome.
