Whirlpool T/L 3RLBR8543JQ0 spinning slow
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool T/L 3RLBR8543JQ0 spinning slow
Viewing 15 posts - 1 through 15 (of 24 total)
  • #25800
    senseib
    Have to go & look at this machine tomorrow. Not had much experience with these American style top loaders. Customer says it wont do the fast spin, only spins slowly!
    Any tips as to what it might be gratefully received ❓
    #207640
    roly16
    Re: Whirlpool T/L 3RLBR8543JQ0 spinning slow
    It would be worth taking the flexible drive between the motor and gearbox, 481932528035 [about £9] as the plastic arms break, although this usually results in no agitation either. Check the start capacitor first though as that’s easier to do.
    These machines are quite easy to work on once you know how to get into them. I’ll pm you my mobile no. in case you want a hand while you’re on site.
    geoff
    #207641
    spanner51
    Usually when the drive coupling is broken, the sympton is no spin and no agitation. A worn drive clutch will cause machine to spin slow p/n 481969018152. It is not too dificult to fit, and is available fron connect. Hope this helps.
    #207642
    senseib
    Flexible drive looks good, pretty sure it is the clutch – but to get to it do I have to take motor off? – seems to be held by two brackets at top & bottom.
    Priced clutch-up at masterparts thanks for the p/n – spanner51
    Would appreciate any tips with this one looks tricky!
    #207643
    gegsy
    If you can grab the splines of the gearbox (from inside tub with agitater off) and if you can turn the shaft in either direction, then you most certainly have a damaged gearbox.
    Had a few where this was the culprit, allowing it to wash fine but spin was laboured or non existent. Even had a new gearbox that was faulty 👿
    senseib
    Yep – just taken agitator off can turn the splined shaft in both direction by hand – knackered gear box then?
    Wouldnt want to be an American washer engineer!
    #207645
    gegsy
    Yep, bolloxed 😈
    These are nice to work on TBH, once you get used to them.
    senseib
    Any idea what the p/n for the gear box is? Although I’ve feeling it will probably write the job off!
    #207647
    gegsy
    P/no 481903949118 – £110.66 inc VAT IIRC
    4819 522 28008
    gegsy
    Chris that one fits – AWG348/1, AWM909 and 3LSR5233AW.
    Have they changed it,it has been a while since last one :con:
    johnmac11
    On of these strange anomalies of life, the retail price of the new part number is £61 + VAT
    John
    #207651
    johnmac11
    gegsy wrote:Chris that one fits – AWG348/1, AWM909 and 3LSR5233AW.
    Yep the number Chris has given is for the superseded part and will do the job.
    John
    #207652
    gegsy
    Cheers John, thought that might of been it. Its been a while 😉
    senseib
    Thanks for all the advice lads – At least i know what to look for next time before i drag its heavy ass in!!! 🙁
