Wierd WMA
Home Forums General Trade Forum Wierd WMA
Viewing 15 posts - 1 through 15 (of 31 total)
  • #9228
    Goatboy
    A customer dumped a WMA in my shop for scrapping. Bearings are knacked as usual.
    ‘That’ll make a nice re-con’ I thinks. 🙂
    When I was moving it, it made a very loud thumping noise, like, say a motor boucing around inside the cabinet; so I has a look. Sure enough, the motor has snapped off the tub!
    The bearings haven’t collapsed, they’re just rumbling. The motor hasn’t snapped the plastic tub; the two metal, threaded lugs on the front of the motor have snapped off!
    The machine is old enough to of had bearings in there already. Maybe someone over-tightened the motor.
    I think I can ‘Heath Robinson’ the motor back on, I just wondered if anyone had seen this before, coz I aint.
    #133036
    Re: Wierd WMA
    Goatboy wrote:Maybe someone over-tightened the motor.
    Or :lesson:
    … more likely someone replaced the belt recently with an undersized none S-T-R-E-T-C-H belt???????????????
    Goatboy
    Re: Wierd WMA
    The belt is a genuine elastic one!
    1153 J5 EL – 1613202001
    The belt is completely goosed too! Not snapped, but cracked beyond reconition, and groves missing.
    We need Chief Inspector Taggart for this one. This machine was abused before it died!
    #133038
    Re: Wierd WMA
    Wrong belt….it should be 1613202002, size 1158 5PJE
    Good call, Martin.
    #133039
    Goatboy
    Re: Wierd WMA
    Nice one Martin. 😀
    Can I call you Taggart from now on?
    5mm difference and it snapped the motor, wow! I wonder if a Hotpoint engineer did that.
    #133040
    jimbo2207
    Re: Wierd WMA
    Naaa, no hotpoint engineer would do that, we all carry wma belts as van stock, anyway, the only time we change belts on wma’s is when we replace bearings (long and often), we use the rear tank kit which includes belt, heater and suspension pegs.
    #133041
    Goatboy
    Re: Wierd WMA
    OK. It must of been a cowboy. “Oh, this one is only 5mm smaller….” 🙄
    #133042
    Re: Wierd WMA
    Curiouser & curiouser…I went to a WMA this morning to fit a new belt (under 3 minutes using the bag tie method 🙂 ).
    The new, genuine hotpoint belt, #1603287, size 1158 5PJE, code 1613202002.
    The faulty belt which I am certain is the original, size 1153 J5EL, code 16132002001.
    The old belt had slipped off and when I compared it with the new belt it was a fair bit longer, no doubt due to stretching, but it would appear from this that the belt on Goatboy’s WMA was genuine.
    #133043
    Re: Wierd WMA
    Kev put a post up about stretch belts ages ago – different stretch rates from different manufacturers giving different tension IIRC. That might account for it.
    Re: Wierd WMA
    jimbo2207 wrote:Naaa, no hotpoint engineer would do that, we all carry wma belts as van stock, anyway, the only time we change belts on wma’s is when we replace bearings (long and often), we use the rear tank kit which includes belt, heater and suspension pegs.
    Got a part number for that Jimbo? We end up re using heaters and can be a bit of a pain.
    #133045
    clyde
    Re: Wierd WMA
    The rear tank kit is 1605082
    Clyde 8)
    #133046
    Re: Wierd WMA
    clyde wrote:The rear tank kit is 1605082
    Clyde 8)
    Just tried to order one of these, only to be told ” for Indesit Co, engineers use only” 😥
    #133047
    Dave_Conway
    Re: Wierd WMA
    Who told you that ?
    I can add it to my order tray on Partfinder adn get no silly messages popping up 😕
    #133048
    Re: Wierd WMA
    According ot my usual supplier, who I have no reason to suspect is telling porkies, he has just been given that information on the phone by Hotpoint/Merloni. Have you actually managed to order one of these. ?
    I have tried to find that part on several different WMA’s in partfinder and up to now all come up ‘part not found’
    #133049
    Dave_Conway
    Re: Wierd WMA
    I’ve never actually ordered one but it allows me to add it so in theory it would be despatched.
    No picture of it though, as you say it’s not associated with any models. Hit the “direct order” button then add it 😉
