Re: WMA bearing change
If you smear a little petroleum jelly on to the end of the pins, they slide out easily ,once the tab is pushed back. On refitting, brush the pins with petroleum jelly and they will just push in wth your thumb.
I find it pointless to try to remove the pins holding the drum to the spider I just drill the ends off with an 8mm drill bit and replace with countersunk allen screws that I buy locally at eight quid a hundred. Hotpoint price about four quid each.
Once did a hotpoint 95 bearing change in an hour BLINDFOLDED for a bet and worked without a problem.
Nigel.
