Home › Forums › UK Whitegoods › Moderator/Site Admin Forum › Word Count
- This topic has 359 replies, 9 voices, and was last updated 19 years, 6 months ago by
kwatt.
March 28, 2011 at 8:45 pm #191643
KeymasterRe: Word Count
Been filling holes…
I’m sure there was another one but I can’t find it… :rolls:
But a LOAD of tidying up done as well. Probably a load more to do still.
March 28, 2011 at 9:07 pm #191644iadom
ModeratorRe: Word Count
Oven one looks OK.
On the Tumble dryer one, 1st para: 2nd line, you need to remove ‘that’…
Also might be worth adding that modern electronically controlled dryers of any kind can go into error mode if kept in very cold or sub zero temperatures as the NTC or temp sensor will go ‘out of range’ and stop the dryer from working altogether as the controls think the sensor is faulty.
March 28, 2011 at 9:28 pm #191645kwatt
Ta.
Sorted. With some weirdness. 😕
March 28, 2011 at 10:01 pm #191646iadom
kwatt wrote:Ta.
It doesn’t appear to have changed, it still has the spurious ‘that’ on the second line. 😕
March 28, 2011 at 10:08 pm #191647kwatt
My brain hurts now…
March 28, 2011 at 10:12 pm #191648iadom
Its this bit that doesn’t scan.
‘you have to consider where that you will install the ‘
March 28, 2011 at 10:14 pm #191649kwatt
Okay, I think I got it. 😕
On another note, can everyone have a look at the main menu/s on the site and tell me if they spot any obvious errors?
The reason being that we need to synch them with the forums and, before we do, I’d rather they were right and with no glaring errors…
…like the stuff I missed. 😳
March 28, 2011 at 10:35 pm #191650iadom
Had a quick blitz through a few, there are so many its difficult to keep a check.
I assume you mean the drop down menus across the top of the home/forum pages.
The banner adds are still obscuring the drop down menus, same in both IE and Chrome. If I then refresh the page the drop down menu then covers the add banner as it should.
March 28, 2011 at 10:49 pm #191651kwatt
Odd, works fine in Safari. I’ll check on others tomorrow.
Yes, it’s the drop down menus I’m on about.
March 28, 2011 at 11:11 pm #191652iadom
Now seems to be working fine on both IE & Chrome , it did the overlay thingy a couple of times but now seems to have cleared. 😕
April 2, 2011 at 6:21 pm #191653kwatt
Another mould one based on a lot of digging about.
Can you tell me if you think that will make sense to the great unwashed please?
Ta
April 2, 2011 at 7:15 pm #191654iadom
Good article…..however, 😛
2nd paragraph you have plastic out drum, you are missing an ‘er’.
In the Low Temperature passage you have an ‘e’ missing from are on the first line.
April 2, 2011 at 7:22 pm #191655kwatt
Ta, sort them in a bit.
May 17, 2011 at 5:41 pm #191656kwatt
I got sick of having to answer the same questions over and over about these <bleep<ing Whirlpool piles… article here.
May 17, 2011 at 7:15 pm #191657iadom
Only spotted one small faux pas, 😉
F2. I’m sure you may want to kick it, thump it or jump on it, but unless its a Scots thing I don’t think I would ‘nut it’.
the old Glasgow kiss eh.
