Home › Forums › General Trade Forum › Working on Dual fuel range cooker – Gas Safe registered?
- This topic has 41 replies, 13 voices, and was last updated 14 years ago by
twicknix.
March 26, 2012 at 12:23 pm #68633
twicknix
ParticipantHi,
Got a call saying that the electric oven on the range cooker requires a new thermostat. Normally I would do it but this one is a dual fuel, I am unsure on what I can do to it.
I seem to recall that if I interfere a gas appliance without a gas safe certificate then I am breaking the law. Does this applies to dual fuel range cooker?
March 26, 2012 at 12:39 pm #372075johnmac11
ParticipantRe: Working on Dual fuel range cooker – Gas Safe registered?
The same question keeps popping up now and then and if you look to the related topics below you will get your answer.
The bottom line is that as long as you don’t disconnect any gas carrying part of the cooker then there is nothing to stop you fitting a stat.
John
March 26, 2012 at 9:36 pm #372076squadman
Surely thats not the bottom line, a lot of Gas hobs as fitted to your typical range cooker may require that the burners and other fittings are seperated from the hob surround which is then either raised or lifted off the appliance ? In such cases no break into the Gas is required, BUT if the burners are then left suspended and one cannot help but move the burners and associated supply pipes around during disassembly and reassembly. That being the scenario as I see it, a safety check would be mandatory ( pressure tests ) Manometer required and of course the engineer would need to be Gas Safe.
This question always comes up and my point is that IF no gas parts are broken into, no parts are going to be flexed or any work performed where your work could create a Gas Leak then it may be possible to do such a job. However the whole idea of being Gas Safe registered is that you have the training and ability to perform the testing along with the necessary PLI without which you are leaving yourself, the public and whoever open to danger and legal recourse.
Experience will allow you to make a judgement if any work such as this falls into the area where you can work safely and legally and if you have any doubts then walk away. I did this myself just last week despite a customer trying to pressurise me to do a job which I was not comfortable or qualified to perform, she even called up my office to complain I was just being a jobsworth. I was happy with that as I could sleep that night and lets not forget that if she was ringing to complain I would not do the job who would she be ringing if it all went wrong ?
March 27, 2012 at 4:17 am #372077johnmac11
Look at this previous post and you will see a couple of quotes that I have taken from Gassafe bulletins.
general-trade-forum/working-gas-cookers-information-t66145-15.html
I suppose you need to look at each job and see if it can be done without any impact on the gas side.
John
March 27, 2012 at 7:17 am #372078twicknix
I have somewhat taken on board on what to do with dual fuel range cooker along the line of as long you don’t touch the gas parts.
After reading various threads, it is a grey area, in this instance the job require a new thermostat, simple enough job for a basic electric oven.
Pulled the cooker out, easy enough, removed the rear access by the use of screws (easy enough), got good access to replace the fan, element and of course the probe itself.
BUT – the knob itself was proving a real headache.
Plan A – You have to remove the top which meant you have to move the gas burners (no go area).
Plan B – remove the side panel (no go area as you need to move the top in order to remove the side panel)
Plan C – remove the front facia (no go area as you need to move the top in order to remove the facia)
Conclusion – well and truly balls up! And of course this was a Technic Range cooker – no parts listed on my three suppliers. All the best for the next person! I advised the client to ring Technic helpline and they will send someone out. I warned that the client will have to pay their prices as it’s the only way to get it fixed!
March 27, 2012 at 7:25 am #372079DrDill
The fact is any one can repair a Dual Fuel Cooker, anyone, as long as the gas path is not interupted. Also any one can mess about with the electrical side of an appliance, what you hope is that who ever does they are suitably experienced to be safe. At the end of the day we as unqualified electricians can test the safty of an appliance with suitable test equipment and also able to use leak detector or sniffer to make sure we havnt caused a leak, if a leak is found or a elctrical installation found to be unsafe then the householder can be informed and the fault fixed by the relevent trade. This is best working practice, and something we should all follow.
March 27, 2012 at 7:42 am #372080Martin
johnmac11 wrote:The bottom line is that as long as you don’t disconnect any gas carrying part of the cooker then there is nothing to stop you fitting a stat.
Indeed not or at least that is the general acceptable excuse for allowing non gas safe engineers and DIY’ers dabbling with dual fuel stuff. As John said it has been long been debated over several threads that pop up every season or so. But the one vital issue, that on each occasion is overlooked, is the question of GAS SAFETY. :rolls:
How can any responsible company or individual access the safety factor NOT being Gas Safe qualified? How can you know if the installation you are attempting to replace the stat/element/spark generator etc to complies with the gas regulations in the first place? Or that the room where it is located is adequately ventilated?
And that all important “bottom line” question once the repair has been successfully completed : IS THE APPLIANCE SAFE TO USE?
GasSafe wrote:Safety Checks include:
•A test on the integrity of your gas pipework
•A check on the ventilation provision
•Check on any appliances safety controls
•Visual check of flues, flueways and terminals
•A visual check on the flame pictures
•Flue flow tests where applicable
•Spillage tests on appliances
•Operating pressures of appliances gas supplies
•Gas rating of appliances
•A check for compliance with current Building Regulations and British Standards
•Issuing of certificates to comply with relevant lawsI highlighted Gas safe’s “bottom line” in red by the way. 😀
March 27, 2012 at 7:58 am #372081stevebunyan
ParticipantWorking on Dual fuel range cooker – Gas Safe registered?
The way I stay with in regulations is when I come accross a job that may have potential of crossing over into gas safe territory is explain to the customer that I can do the repair but due to gas safe regs I can’t reconnect the appliance until it has been tested, is that ok? When I get the go ahead I disconnect at the bayonet and do the job and leave disconnected. I than phone my friendly gas safe engineer to re connect and every one happy.
Sent from Steves
iPhone using TapatalkMarch 27, 2012 at 8:16 am #372082Martin
stevebunyan wrote:I than phone my friendly gas safe engineer to re connect and every one happy.
….and your customer is happy for 2 call-outs for one job, you to fix it and your Gas Safe engineer to connect it up later?
Wouldn’t they figure cutting out the middle man and getting the Gas Safe guy to do both repair and test?
Or maybe could pass on the work to him for a little commission? 💡 😀 😉
March 27, 2012 at 8:36 am #372083admin
KeymasterWorking on Dual fuel range cooker – Gas Safe registered?
IF YOU disconnect the bayonet then YOU must be gas safe registered. IF the bayonet has been disconnected by the customer then you have not broken a gas seal the customer has to allow cleaning ect. That is as long as you do not carry out any gas work.
Bryan
March 27, 2012 at 9:01 am #372084philfish
I have seen it many times, When someone including myself goes to change the stat as john says they have to take the top off more then likely now a days it is a cheap chinese piece of rubbish. So when you remove the lid the cups are left dangling in mid air you catch one, touch it, knock it or it could just be loose from the factory etc so the union nut becomes loose at the gas tap. You have to tighten it back up! Simple mistake easy remedy but the gas seal WILL have been broken and then you are in the deep brown stuff and is not even your fault.
If i was not gas safe i would at most just simply stick to elements and leave the rest alone.
Just out of curiosity i wonder where you would stand if you was not gas safe pulled out the appliance to find no stability/safety chain? (which most do not have and yet again not your fault). You could not issue a warning and even if you did you could not fill out the correct paperwork to issue the warning certificate as martin touched on.
Those are two very very common scenarios with out even getting in to the gas side of things.
I know what gas safe says but to me it is still a very grey area. It is better to be belt and braces and be qualified etc if at all possible (yes i also know the restrictions on this). With how liability stands in this country now your pli company would drop you like a hot potato and pleading with the judge who will more then likely have asked gas safe to look at the job and who WILL be providing evidence against you (although they made the rules!and none of it is your fault) will get you no where IMO.Phil
March 27, 2012 at 11:23 am #372085twicknix
I think it might be worth finding out what’s the official line that WTA says, as a member, it would be helpful to follow the guidelines rather than guess and hope for the best.
So what’s the official line then? Personally I would be happier to say that if WTA advised against working on dual fuel range unless you are gas safe registered. This way we all got our backs covered.
It would be such a pity to miss out the lucrative market as most people in affluent area tend to have the range cooker. Goodness knows why? I have never seen people using all six burners or even used the griddle, let alone using the spit roast oven! Status symbol I guess, just like those expensive coffee machine we see in higher end kitchens.
March 27, 2012 at 1:27 pm #372086kwatt
KeymasterRe: Working on Dual fuel range cooker – Gas Safe registered?
I asked the HSE when I was there.
I also asked CORGI.
Then asked Gas Safe.
All give the same answer, we’re not really sure as it’s never been tested. Then go onto say that…
Technically, you can repair non-gas carrying components within the legislation.
However, that same legislation says that the person responsible if it all goes sideways, is the one that last attended. If you were the last one to work on the appliance and were not Gas Safe registered you can imagine how that could be painted, especially so if something happens not long after you attend.
I tackled the Gas Safe guy on it again a year ago as this question comes up over and over and, the answer above has not changed.
So the answer is, it’s up to you as the guidelines are not clear and there has been no crystal clear guidance from the HSE down.
The danger of course is that something does happen, the HSE does choose to prosecute and the judge decides that you should have been Gas Safe then you could end up in prison never mind fined.
As they say though, it has never been tested in a court and, it’s never been a problem in all the time that the gas legislation has existed. There is therefore no answer.
Unless someone wants to volunteer to be the first one prosecuted? 😉
I think the TA guys are going to try again to get further clarification from the HSE but I wouldn’t hold your breath on an answer or, if one is forthcoming, that you’ll like it.
I could go on about this for ages as it is a complex PITA but I’ll can it.
March 27, 2012 at 4:03 pm #372087admin
OK
As The WTA has requested a formal response concerning this there is as follows :
Official response from gas safe concerning the repair of range cookers :
Date issued: 25 August 2011
Note: This version of Technical Bulletin (TB) 043 replaces the version originally published 19 August 2010 which is now withdrawn. This version has been reviewed and where appropriate revised to ensure that it remains both current and relevant.
This Technical Bulletin provides guidance to self employed persons and businesses that are not registered with Gas Safe Register regarding electrical work that can be undertaken without being registered with Gas Safe Register
Introduction
Following correspondence between the Electrical Contractors Association (ECA) and the Health and Safety Executive (HSE) in Great Britain (GB) regarding electrical work that can be carried out on a gas appliance without a requirement for being registered with Gas Safe Register, the following statement has been issued by the ECA and has been “endorsed” by the HSE in GB and the Electrical Safety Council (ESC).
Note: “ Where an electrical contractor is installing or maintaining electrical components of a gas system, e.g. solenoid valves, pumps, time switches, provided this work does not involve disconnection of a gas fitting, i.e. breaking into the gas path or combustion system, registration with Gas Safe Register is not necessary.”Therefor if you are replacing an electrical part you do not need to be gas safe registered..BUT due care and attention is required.
My engineers ALWAYS pass over any joints ect a leak detector just in case.Bryan
March 27, 2012 at 5:05 pm #372088Martin
So to sum up, it’s OK to dabble but if it blows up you is the one in trouble. Commercial need to find a way around the safety aspect gets the green light (or should that be blue flame?)….
The simple fact is that there are too many dual fuel appliances and too few gas safe engineers. Hence the relaxation in the regs. If British Gas can get a grip of all this confusion the loophole will surely be closed. Meanwhile until some twat does indeed cock up on a job and blow a family up the grey area will always be applied. :rolls:
