Zanussi washer dryer tripping the RCD.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi washer dryer tripping the RCD.
Viewing 15 posts - 1 through 15 (of 24 total)
  • #50969
    Davethebass
    Morning Gents,
    Our approx 4-5 year old Zanussi WJD1667W (prod number 914601825/00) tripped the kitchen RCD this morning after we put in a load.
    The machine filled OK as there was water in the bottom of the drum, the usual height. I’m an Electronics technician by trade so decided to hunt deeper 🙂
    I opened the door (to halt the cycle) then reset the RCD. On closing the door the machine powered up and did a roll of the drum in either direction, then it settled for a bit. The ‘Jetstream’ pump started fine and the drum went into normal wash rotation.
    Then the RCD tripped.
    I unplugged, then I laid the M/c on it’s side and had a look around and found a fair bit of carbon dust from the brushed drum motor , ‘Aha!’, insulation breakdown to earth I thought…. can of compressed air and solvent cleaner later a gleaming motor and interconnects. Powered up, went through the same palaver again, AOK until (I think) the m/c starts to want to heat the water in the drum. I’m thinking the heating element is leaking current to earth… fair assumption?
    The drum motor spins up to 1600 rpm no problems, the drain pump is fine, the ‘jetwash’ pump motor is fine as are the elements in the air heating element on top of the drum… I can test-run each spin/drain/dry cycle by advancing through the programmes manually.
    Where is the water heating element?! I can’t find it. Has any of you fella’s had this happen before?
    I’m all lathered up (geddit… a pun….).
    Any advice?
    Ta in advance.
    Dave the bass.
    #306498
    TheSpinDoctor
    Re: Zanussi washer dryer tripping the RCD.
    Hi.
    Worktop & back half of cabinet can be removed to allow access to the wash heater at the rear of the tub.
    #306499
    Davethebass
    TheSpinDoctor wrote:Hi.
    Thanks for the reply SpinDr, the worktop I’ve had off this morning to check the dryer heater elements which are all clear to ground and measure about 56 ohm across each element.
    I couldn’t see how the back half of the cab came off TBH. You sure it deffo does? I’ll have a look again tonight if you’re sure it does!
    Thanks for the quick reply, really appreciate the help,
    Cheers,
    Dave the bass.
    #306500
    Davethebass
    Done it, thanks Mr SpinDr…
    Found the heater element…
    …yeucky!…
    Yup, <100K ohm to earth on an insulation tester.
    Now to source one, 240V 1950Watt.
    DTB
    #306501
    HERE
    Davethebass
    Thanks for the linky Mr Penguin, local independent repair shop has ’em. I’ll pick up tomorrow on the way home.
    A temperature sensor is in the element housing too I notice.
    Thanks for all the help fella’s, really appreciate it.
    DTB
    #306503
    Davethebass
    BTW, that gunge that is all over the element, we find a lot of that in the filter too. Its a slimey grey goo, sometimes with stringy deposits.
    What is it? It can’t be good for the machine and element, it looks like there’s a fair bit of it in the water heating cavity too, I’ll clean it all out (natch) before fitting the new element.
    We’ve got hard water here (NW Kent) we’re told.
    DTB
    #306504
    TheSpinDoctor
    Hi.
    I know what the water in NW Kent is hard as I live there. Limescale is a real problem around here. Also probably you will find some of that stuff is detergent residue. A boil wash without laundry & half a measure of a quality brand biological powder based detergent periodicall will help.
    #306505
    Davethebass
    Ooo, thanks for that tip, we didn’t know that.
    Thanks again.
    #306506
    Davethebass
    Update.
    I’ve fitted the new element and all appears to be fine and dandy now. Many thanks for the help and advice.
    …next question…
    Is this part of the dryer supposed to be covered in mould and gunge!!!???
    Might explain why the clothes smell ‘odd’ on the rare occasion the dryer part is used I’m guessing.
    Is it OK to disconnect this section and give it a good wash out on the end of a hose in the garden to try and shift some of the detritus?
    Dave the bass.
    #306507
    TheSpinDoctor
    Hi.
    Cleaning the condenser would be well advised.
    #306508
    Davethebass
    Aaaahhh! A ‘condenser’, so thats what it called 🙂
    Thanks again.
    Zoltan Zanussi has just completed his 2nd load and appears to recovering well after the operation.
    DTB
    #306509
    Davethebass
    Victory was short lived 🙁 After its initial successful wash it’s developed another fault. Bum!
    We put on another normal load, 40 degC and it stopped during a run, its paused itself in mid-cycle. I’m sure it’s over filling too, water is sitting about 1/3 up the door window. I’ve never noticed it do that before.
    No fault code.
    We tried another load and another temp, this time it filled to the same (possibly) too high level and turned off the row of temp LEDS. We’d selected 30 degC again. Nope, it’s not having it. It lets us drain the wash and then opens the door release OK.
    meh.
    Any ideas?
    Dave the defeated.
    #306510
    TheSpinDoctor
    I would check the heater wiring connections, sump hose, drain filter & air chamber if I were you.
    #306511
    Davethebass
    TheSpinDoctor wrote:I would check the heater wiring connections, sump hose, drain filter & air chamber if I were you.
    10/10 SpinDr
    Partly my fault TBH. Cable dressing, one of the heater connectors was disconnected. Further fault finding showed I’d left that cable too tight and when the machine went into spin I reckoned it popped off as the drum was wobbling about.
    While the back was off I took the opportunity to clean out the condenser…
    Shiny clean condenser, more effective drying and less smells? We’ll see, I’ll run a maintenance wash after we’ve got a couple of regular washes out the way.
    ….if the blummen thing completes a cycle this time..
    Fingers crossed.
    As ever, thank you Sir .
    DTB
