Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › zanussi zwf 12070
- This topic has 24 replies, 8 voices, and was last updated 16 years, 1 month ago by
kneadman.
February 16, 2010 at 4:12 pm #52544
kneadman
Participanthi was wondering if the module (pcb) can be tested in any way.
February 16, 2010 at 10:44 pm #312215aqualectric
ParticipantRe: zanussi zwf 12070
Not really – post the fault you have and we may be able to help. 😉
February 17, 2010 at 7:48 pm #312216kneadman
washing machine was working fine then next use machine does not fill up does not matter which wash cycle chosen.
February 17, 2010 at 9:11 pm #312217aqualectric
Does it spin? Can the pump be heard running? Does the door lock? The machine not filling is possibly a valve fault but the door will lock and the pump will run first. Please confirm if the machine will do anything else……and what that “anything else” is….. 😕
February 17, 2010 at 11:50 pm #312218kneadman
thanks for reply the pump is running and the door lock appears to be working as door lock lights up…have checked drain hose for blockages all clear. have checked fill hose which is working. does not operate any programs or will not fill.
February 18, 2010 at 1:44 am #312219aqualectric
It is worth checking the motor brushes first to see if they are worn out, and the water fill valve solenoid.
Power off before any inspection starts. :plug:
Hope that helps.
February 18, 2010 at 7:52 pm #312220kneadman
Hi have checked the motor.. brushes appear fine good 30mm left on them.. solid no cracks ect.. have checked both solinoids.. main inlet reads 3.62ohms the other 3.68ohms… any suggestions.
February 18, 2010 at 9:57 pm #312221aqualectric
Next thing to try….Power off first…:plug:
Pull the pressure switch hoses off and try it again. If it does fill then it could be a blocked pressure chamber on the side of the sump hose. (do not let it fill too much; about 5 seconds at most). The small rubber hose goes to it from the pressure switch. 😉
Word of warning – Do not blow into the pressure switch, it is a sensitive electronic device and you will probably damage it as a result.
Failing that, it’s the PCB…….. 😥
A.
February 18, 2010 at 11:16 pm #312222kneadman
hi have tried disconnection of hose to pressure switch however still does not fill…I checked the drain hose from the bottom on first day said hose has a plastic ball within through check revealed no blockage within hose or around the ball again this goes all the way up to pressure switch and was clear so with pressure switch isolated machine does not fill so i guess its back to the pcb ?….
February 19, 2010 at 8:47 am #312223aqualectric
Looks like it…….. 😥 Not a cheap fix, I’m afraid.
A.
February 19, 2010 at 11:01 am #312224kneadman
Hi would like to thank you for your help and congratulate all concerned in running the site I take it a new board will need to be programmed or will the part work straight from supplier…hoping a complaint direct to zanussi will prove fruitful the machine is only 14 months old….
February 20, 2010 at 1:15 pm #312225A1TEC
Have you accessed the machine diagnostics?,this will show fault code and point you in the correct direction, also the last fault can be reset.
I had one do the same 2 months back, entered the diagnostics,reset and away the machine went.
John.February 20, 2010 at 2:02 pm #312226kneadman
hi to enter machine diagnostics I take it you require an interface n laptop with diagnostic programme….which I don’t have did note a 4 pin connection on the pcb which i examined with large magnification did not see any obvious corrosion or burning tracking ect so if pcb board would need to be a component fault….any easy solution… ❓
February 20, 2010 at 6:16 pm #312227A1TEC
No lap top required,all you need is a engineer with the service manual. 😆
John.February 20, 2010 at 10:59 pm #312228kneadman
cheers will try that first……
