zanussi zwf1427w
Viewing 15 posts - 1 through 15 (of 22 total)
  • #53026
    ajkwales
    Just put a load in my washing machine, turned it to wash
    2 mins later the beeper goes off as if the program as
    finished..
    there is no error code, can hear the motor but nothing happens
    please help!!
    thanks
    ajk
    #314111
    TheSpinDoctor
    Re: zanussi zwf1427w
    Hi.
    Does the door lock?
    If so, does it start to fill?
    If so, does the drum turn?
    Please advise.
    #314112
    ajkwales
    sorry
    yes the door locks but is doesnt fill or the drum dont turn.
    you can hear the motor but after about 2 mins it beeps and the timer
    goes back to zero, a if its finished the program..
    thanks again
    #314113
    ajkwales
    any ideas anyone please?
    #314114
    TheSpinDoctor
    If you have a suitable test meter, I would advise you test the appliance for insulation faults.
    #314115
    odom
    I would suspect the “motor” sound you’re hearing is actually the valves opening – is it a “buzzing” sort of sound? Have you checked that there are no kinks in the inlet hose(s) and that there is water pressure to the machine? No water going in would cause machine to abort programme about two mins into wash.
    #314116
    TheSpinDoctor
    odom wrote:No water going in would cause machine to abort programme about two mins into wash.
    It would, but it would display E10 & not 0.
    #314117
    ajkwales
    odom wrote:I would suspect the “motor” sound you’re hearing is actually the valves opening – is it a “buzzing” sort of sound? Have you checked that there are no kinks in the inlet hose(s) and that there is water pressure to the machine? No water going in would cause machine to abort programme about two mins into wash.
    yes it does sound like a buzzing sound, there arent any kinks in the pipe going into the machine.
    would there be kinks in the inside pipes?
    (sorry but i know nothing about machines as you can gather!!!)
    thanks
    #314118
    An earth leakage issue on the heater will cause this problem. Did one just today….
    ajkwales
    Hiya
    thanks all for your replies, had engineer out turns out
    the element itself is faulty..
    Does anyone know the part number i need for this
    thanks once more
    alana
    #314120
    TheSpinDoctor
    132 10 20-21 / 4 is what you require.
    #314121
    ajkwales
    Hiya all
    Me AGAIN!!!
    Replaced the heater now the machine seems to keep filling now with the
    water in the prewash tray.
    Spin now works
    thanks
    alanaxx
    #314122
    ajkwales
    left it filling to see what happens, seems to be washing now but the
    water in the machine is three quarters full..
    Never noticed this much water before is this normal????
    alanaxx
    #314123
    TheSpinDoctor
    Are you sure that there isn’t a wire come off the heater?
    #314124
    ajkwales
    all wires on
    seems to be working ok apart from it filling so much
