Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › zanussi zwf1427w
- This topic has 21 replies, 5 voices, and was last updated 16 years, 1 month ago by
ajkwales.
March 6, 2010 at 12:22 pm #53026
ajkwales
ParticipantJust put a load in my washing machine, turned it to wash
2 mins later the beeper goes off as if the program as
finished..there is no error code, can hear the motor but nothing happens
please help!!
thanks
ajkMarch 6, 2010 at 8:41 pm #314111TheSpinDoctor
ParticipantRe: zanussi zwf1427w
Hi.
Does the door lock?
If so, does it start to fill?
If so, does the drum turn?
Please advise.
March 7, 2010 at 2:31 pm #314112ajkwales
sorry
yes the door locks but is doesnt fill or the drum dont turn.
you can hear the motor but after about 2 mins it beeps and the timer
goes back to zero, a if its finished the program..
thanks againMarch 8, 2010 at 1:17 pm #314113ajkwales
any ideas anyone please?
March 8, 2010 at 5:10 pm #314114TheSpinDoctor
If you have a suitable test meter, I would advise you test the appliance for insulation faults.
March 8, 2010 at 5:41 pm #314115odom
I would suspect the “motor” sound you’re hearing is actually the valves opening – is it a “buzzing” sort of sound? Have you checked that there are no kinks in the inlet hose(s) and that there is water pressure to the machine? No water going in would cause machine to abort programme about two mins into wash.
March 8, 2010 at 7:43 pm #314116TheSpinDoctor
odom wrote:No water going in would cause machine to abort programme about two mins into wash.
It would, but it would display E10 & not 0.
March 8, 2010 at 9:53 pm #314117ajkwales
odom wrote:I would suspect the “motor” sound you’re hearing is actually the valves opening – is it a “buzzing” sort of sound? Have you checked that there are no kinks in the inlet hose(s) and that there is water pressure to the machine? No water going in would cause machine to abort programme about two mins into wash.
yes it does sound like a buzzing sound, there arent any kinks in the pipe going into the machine.
would there be kinks in the inside pipes?(sorry but i know nothing about machines as you can gather!!!)
thanksMarch 9, 2010 at 12:15 am #314118Penguin45
An earth leakage issue on the heater will cause this problem. Did one just today….
March 9, 2010 at 4:22 pm #314119ajkwales
Hiya
thanks all for your replies, had engineer out turns out
the element itself is faulty..Does anyone know the part number i need for this
thanks once more
alana
March 9, 2010 at 4:27 pm #314120TheSpinDoctor
132 10 20-21 / 4 is what you require.
March 11, 2010 at 5:28 pm #314121ajkwales
Hiya all
Me AGAIN!!!Replaced the heater now the machine seems to keep filling now with the
water in the prewash tray.Spin now works
thanks
alanaxxMarch 11, 2010 at 6:10 pm #314122ajkwales
left it filling to see what happens, seems to be washing now but the
water in the machine is three quarters full..Never noticed this much water before is this normal????
alanaxx
March 11, 2010 at 6:22 pm #314123TheSpinDoctor
Are you sure that there isn’t a wire come off the heater?
March 11, 2010 at 6:47 pm #314124ajkwales
all wires on
seems to be working ok apart from it filling so much
