1ne-2wo-3hree
ParticipantRe: Aquarius 6kg will not empty
Many thanks for the contact.
Would the unit need to be programmed after repair and reinstallation in machine?
Thnx Rick1ne-2wo-3hree
Some additional considerations regarding my problem:
– The new motor could be faulty!!??
– although the machine partly cycles could the control module need reprogramming?
– I gather from my search for a new module cheapest £86.00 it would require programming once fitted. Is this a job for the expert?
Rick1ne-2wo-3hree
Many thanks each and all for your help and advice. I will check the wiring and the board and thereafter the board for any signs. Difficult to test without removing?.. I suspect I will have to invest in a new board ……….. which sounds expensive 🙁
Take care Rick
1ne-2wo-3hree
No the old pump looks fine and shows no sign of overheating. I did tilt the machine to replace the motor and check the filter. Could the pressure switch need resetting? If so please can you say where it can be found and what needs to be done to reset it?
Rick1ne-2wo-3hree
Many thanks for your reply. WMA58P would that be the model number from the bar code?Thanks Rick
