A.Cowell
ParticipantNWAR wrote:The part number for the motor is 481236158334, but I would advise having an engineer out to check that’s what is actually required as these things retail at over £100.
Craig
thank’s for the part number Craig, has anybody any recommended engineers for the ws1 area, Walsall, West mids or is it a yellow pages job,thank’s.
A.Cowell
ParticipantRe: back again about diplomat dishwasher adp 8322 fault
DentedPorsche wrote:Ok, remove the bottom spray arm and start the machine up, if there’s plenty of water being shoved out then the spray arms are blocked, if there’s enough water in the machine and very little being pumped I’d have to suspect a faulty wash pump motor or a blockage in the wash pump.
DPThanks, tried the above doesn,t seem enough water and pressure coming out and when the bottom arm is refitted water comes out of the jets but there isn,t enough pressure to turn it.If anybody has the correct name for the pump required and a possible part number, that would be great.
A.Cowell
NWAR wrote:Adam
Have you checked that the fill hose isn’t kinked or crushed? A favourite is for the hose to get trapped under the back foot of the appliance.
Craig
yes I have the appliance out, away from the work service,pipework ok
