ace-machine-man
ParticipantRe: amana american side by side fridge freezer
Does the defrost stat control the fan, i had a short circuit defrost heater, disconnected the heater to stop tripping but the fan would run for a few seconds and then it stopped, so if the freezer evaporator doesnt get to minus 15 then the fan will not run? Thanks ace
ace-machine-man
Thanks ace
ace-machine-man
ParticipantRe: kuppersbusch dishwasher continually draining
many thanks, that is what it turned out to be, regards ace
November 15, 2012 at 12:23 am in reply to: general electric american side by side getting too cold #384702ace-machine-man
ParticipantRe: general electric american side by side getting too cold
Hi what is a ASM assembly, is it the damper? regards ace
ace-machine-man
ParticipantRe: refrigeration & air con
Dear All, I am currently system trained but I am looking for advice on the requirements needed to carry out R134a repairs, I do R600A but it is my understanding that a further qualification is needed on safe handling and disposal of refrigerants, I appreciate any help or advice.
Regards Ace
ace-machine-man
ParticipantRe: maytag top loader spares and exploded views
Hi yes many thanks, I came up with that part number but I did not see the 2 screws pointing down at rear of bezel, are they hidden? I thought I may need to take the timer knob off to remove the cover bezel to then get to further screws but I did not want to break the timer knob, the other function knobs just pulled off fine.
Regards Ace
ace-machine-man
Thanks for that Jem, any ideas where i can get spares for it, do the microswitches fail? regards ace
ace-machine-man
ParticipantRe: Hoover VHD9163ZD-80 door jammed.
Check Heater for continuity or low insulation, if all ok module could be faulty.
Ace-machine-man
ace-machine-man
ParticipantRe: Manufacturer No 2 looking for agents
Hi Dale
I have my own domestic appliance repair business and cover N, NW, IG and EN postcodes and looking for work in those areas, I am City and Guilds qualified in this trade.
I am qualified on all refrigeration inc systems, laundry, cooking, dishwashers with 27 years experience in the trade.
I look forward to your reply.
Regards
Gary
ace-machine-man
ParticipantRe: ESL 624 leaks from door when washing
is it foaming alot inside when it leaks?
ace-machine-man
ParticipantRe: Gorenje Fridg Freezer Problem
does your model have 1 temperature control knob?
ace-machine-man
ParticipantRe: ZANUSSI TCE7276W
Martin wrote:E50 is a fault relating to the motor and/or the triac that controls it on the circuit board.
If you let me have your email address I can send you the extra info you require. 😉
does it have a start capacitor though?
