Ade-x2
  • Ade-x2
    electrofix wrote:if you message uk whitegoods shop and send a pic of the model plate plus describe where it is they should be able to identify it
    when I looked it up I found 2 listed for the unit. one in the fridge the other in the freezer
    DA47-00320L
    DA47-00321L
    Hi [USER=”4209″]electrofix[/USER],
    yes I need the one for the fridge, which should be the DA47-00321L one but that one has two cables (one at each end of the unit)
    Ade-x2
    electrofix wrote: have you asked the shop ?
    also there are 4 models with same model number but different idents
    when i seached defrost heater i found 2 different ones
    Hi Dave, thanks for your reply!
    No local shop have the spare part so I’ve found it online, ukwhitegoods sells it too but the one it shows as compatible with my model is the one with the double connector. I’ve also have the serial of the fridge I’m not sure if that’s helpful
