Hi David,
THank you so much for replying.I was going to add the PNC No ( 925 – 771 – 737 – 09 on my original message but forgot to add it.
What happens is, if I insert a bulb in the fridge light the bulb stays on.I could prove this by putting my phone inside the fridge on video and shut the door!
The light flickers very slightly when you depress the door switch but doesn’t go out.
I also noticed the small green pilot light goes off when you activate the door switch….is that normal?
if its a board is this something I could purchase or would I have to go through a repair centre?
AGAIN many thanks for your assistance with this
Rgds
Alex
