Am Appliances
  • in reply to: Candy grand vita e21 #469281
    Am Appliances
    Heater relay has been replaced is the thermo fuse the black one on ducting behind front panell or is it the round white one to the left of it?
    in reply to: Candy grand vita e21 #469279
    Am Appliances
    Do you know if its a microswitch or is it a sensor, can it be tested with meter?, ,I havent touched any hoover/candy appliances for years so sorry for all the questions
    in reply to: Candy grand vita e21 #469278
    Am Appliances
    It starts cycle sometimes flashes the error straight away or will throw the code up after a while but no heat in dryer also, I’ve had the heater relay rrplaced on the module as I know that is a common fault, I will strip it down to get to the switch, don’t get a water full light just the error code. This model has no pump its tray at bottom.
    in reply to: Candy grand vita e21 #469276
    Am Appliances
    Hi its GVSC9DG80. SER NO 3110082819100204
    in reply to: Candy grand vita e21 #469274
    Am Appliances
    Do you know where the pressure switch is located this dryer has no pump tray at the bottom?
