Andrew McHugh
Viewing 1 post (of 1 total)
  • Andrew McHugh
    I know this thread is quite long in the tooth now but did anyone ever solve the issue with the replacement PCB / double beep / only works when you go via test mode issue? It’s quite likely we’ll replace our dryer in the near-ish future so can live with the workaround in the meantime but good to know if anyone cracked it. thanks!
