Andrew Metcalf
  • in reply to: Error Codes For Tecnik DW2677/1 #472113
    Andrew Metcalf
    Hi Again,
    It is 12 flashes for sure. I have disconnected and re-connected all of the plugs to the control board and it now seems to be running. Just letting it run through a cycle.
    I reckon there is a bad contact somewhere..
    Andy
    in reply to: Error Codes For Tecnik DW2677/1 #472111
    Andrew Metcalf
    Hi Dave,
    Thanks for the reply. I took the door off and have had a good look at the wires two of the thin black ones going to the programmer looked suspect but after taking back the wire insulation they are Ok. Where is the diverter valve?.
    I can see the temp probe, the pressure switch the water inlet valve at the water inlet at the back and a solenoid on the salt dispenser.
    Andy
