Andy Cordwell
  • in reply to: AEG Main Oven Thermostat #460058
    Andy Cordwell
    Evening Dave
    So the story goes on. The thermostat is still miles out so I have contacted the supplier to question it. Looking at the package the new thermostat is an ET52001F8. The DST number on the supplier label is DST506008433001. But on the back of the packaging is DST506008483001. I dont know if there is a difference in the numbers?
    in reply to: AEG Main Oven Thermostat #460056
    Andy Cordwell
    Cheers Dave. I might be missing something completely but I presume your saying put a thermometer close to the temp probe from the thermostat and see what the reading is?
    in reply to: AEG Main Oven Thermostat #460054
    Andy Cordwell
    A new question to ask now. For some reason the thermostat seems to be about twenty degrees out. I wonder if I have a faulty one?
    in reply to: AEG Main Oven Thermostat #460053
    Andy Cordwell
    Hello Electrofix, I can confirm its the model 3210BU-W. I found that my assumption seems to be correct as I found details about the switch change and it seems to be working fine. It seems when you but this item from some suppliers you get a change diagram. But hey ho its working. Thanks for replying.
