andy webster
  • in reply to: HOTPOINT WF 840P FAULT CODE F08 #316501
    andy webster
    Re: HOTPOINT WF 840P FAULT CODE F08
    hmmm.. dont know how long this is but its certainly longer than 2 weeks and still working perfectly…..
    andy….
    not back yet …lol
    in reply to: HOTPOINT WF 840P FAULT CODE F08 #316497
    andy webster
    Ok.. thanks for reply …. i fixed it now. Maybe this is worth putting on the forum for others to read before they buy a new module… i guess mine was a loose connection or something …
    i had F08 fault code but i guess its the same fix (ish ) for any fault code , worth trying all the same.
    All i did was remove the controll module which was very easy… look at tracks on board, wipe it down and put it back…..
    making sure you push all connectors back firmly….. then switch it on and wash … hey presto —— NO FAULT CODES and clean clothes….
    make sure you disable the power supply and only attempt this if you feel competant. otherwise get an engineer to do it first.
