Andy_CC
Viewing 1 post (of 1 total)
  • in reply to: Cannon Harrogate CH60DHKF Top Oven #459017
    Andy_CC
    electrofix wrote:the thermostats normally just clip to the back of switch so gently prising the clips and it will pop off.
    OK , thanks. I’ll give it a go when the replacement arrives
    The bulb sensor is located inside the oven, you will find it clipped up somewhere in side the oven cavity. if you unclip it and poke it back through the hole it comes in on the new sensor can be introduced the same way
    Yep, I’ve found it now – it was hidden by the shelf 🙂
