Ant H
Viewing 1 post (of 1 total)
  • in reply to: Indesit IDF 125 problem #385213
    Ant H
    Re: Indesit IDF 125 problem
    Hi I’ve got the exact model and problem as above however my unit has been installed for some time.
    Please bear with me as I’m new to the site!
    I’ve tried checking the drain pipe which is clear and there’s no obvious external leaks. Also tried pulling the unit out and turning it on it side as suggested. Only a small amount of water came out.
    After turning upright the unit is still stuck with the wash light flashing and can hear the pump running
    Is there any way yo check the tray or trip switch directly?
    Any hints on what I could try next? Thanks for any help
    Ant 🙂
