b-52
  • in reply to: Ariston AVXXL109EX Programm Error #321096
    b-52
    Re: Ariston AVXXL109EX Programm Error
    Yes and i will buy you a barrel of ouzo!! 😯 you will forgot even your name xeexexexe
    in reply to: Ariston AVXXL109EX Programm Error #321093
    b-52
    I final manage to make it work.The problem was-as you say- the connection to NTC ,the wires are lose from the connector pins.
    I want to say a big THANKS for your help!! 😀
    in reply to: Ariston AVXXL109EX Programm Error #321091
    b-52
    Yes that is the status led.
    The valves are working because if it pass that step all the program works ok.If there was a problem with the valves the problem will exist to the rest of the program.or not?
    At the start i hear the valve is opening then after 5 seconds i hear it closes after 5 seconds to 10 it opens again then closes then prewash led flash.
    The water pressure is ok ,that was the place it works before the repair.
    in reply to: Ariston AVXXL109EX Programm Error #321089
    b-52
    I didnt adjust the water sensor.
    I will disassemble it again to check the connections.
    No i didnt remove the main PCB when i change bearings.
    The option buttons are at the left of the contol panel and i count them from the top to the bottom,is that correct?
    The strange is that if it takes water is for 5 seconds then stops then the second led from the left in status leds flash and nothing happens.After 5 minutes takes water again until the water sensor reach the pressure then the program start ,i think that it does not take the water at the correct time.
    Thanks for the reply!
    ps:Yes is a Greek model
