big_benji
  • in reply to: Cooling problem with APM/6325 #160952
    big_benji
    Re: Cooling problem with APM/6325
    The stat arrived today,fitted it at lunch time and my fridge is now working perfectly.Thanks for all your help Dave you have saved me a small fortune.
    in reply to: Cooling problem with APM/6325 #160951
    big_benji
    I have just emailed the link you gave,Thanks again for your help Dave it has been much appreciated.
    in reply to: Cooling problem with APM/6325 #160949
    big_benji
    I have checked the compressor and the outside does feel hot,its not hot enough where it would burn my hand though.Is it possable for me to change the thermostat myself and what sort of money is envolved with buying one?
    in reply to: Cooling problem with APM/6325 #160947
    big_benji
    How will i know if the compressor is actually doing anything,I turned the stat on the fridge down to 1 last night but the temp still remained at 8 degrees,whether it is at 1 or 5 it makes no bearing on the temp.
    in reply to: Cooling problem with APM/6325 #160945
    big_benji
    The motor appears to be switching on and off correctly,The fan at front must work in conjunction with the main motor at the back,ie they both come on at the same time.Have you any ideas of what could be wrong if the compressor is working correctly?
    in reply to: Cooling problem with APM/6325 #160944
    big_benji
    Ok thanks for that.I have now pulled the fridge out and looking at the compressor,I assume this should switch its self on and off.Have you any idea how long the motor will run for before clicking back off,just so i know if i do have a problem.
    in reply to: Cooling problem with APM/6325 #160942
    big_benji
    I’ve removed the ventilation panel from the front of the fridge and i can see a motor with fan there,is this the motor you are talking about?Also,this might a stupid question but what should the internal temperature of the fridge be if i set the unit to 5,its coolest setting? Thanks again
