Blackcat_84
Viewing 1 post (of 1 total)
  • in reply to: BEKO B5T4923IW displaying wrong cycles #487950
    Blackcat_84
    electrofix wrote: first check its not mechanical.
    see if you can find the off position and see where it is
    if not try putting a little bit ( stress little) of wd40 into the rotary sw and work it round a few times and see if things get better
    if all no then a new board it is. I will assume its the display board with the rotary switch but cant promise that.
    you will also probably have a job getting it as its so new
    Thanks for the reply. I disassembled it as much as I could and turned the dial directly. I also thought it was mechanical at first but it seems electrical.
    Edit: to confirm, it was turned on and it was the same: the cycles were still messed up.
