brett twyman
  • in reply to: beko CXFP1582DW Not cooling #468296
    brett twyman
    is there anything i can test with multi meter (not really used one) or should i throw fridge frezzer away i would rather fix it if possible?
    could it be defrost heater ?
    in reply to: beko CXFP1582DW Not cooling #468294
    brett twyman
    the coils in freezer are dripping seems like they are defrosting
    in reply to: beko CXFP1582DW Not cooling #468293
    brett twyman
    no sorry the fridge is 15c so not running atal and the frezzer get to -17 then creeps back to 0 this is all measured on a cheap digital thermometer.the picture above was taken before i defrosted ice that you see
    in reply to: beko CXFP1582DW Not cooling #468292
    brett twyman
    in reply to: beko CXFP1582DW Not cooling #468290
    brett twyman
    hi fan runs whilst open and shut
    in reply to: beko CXFP1582DW Not cooling #468288
    brett twyman
    the freezer is not getting cold enough to freeze some things is what I was meant to write.The freezer feezed a cup of water in top tray but thawed out frozen fruit .The freezer is on 0.5c atm and fridge 15c which it seems to always be at there is a bit of condensation on fridge walls.I have not noticed the compressor turn off tbh but will keep a look out for that.
    Many thanks for your help
    in reply to: beko CXFP1582DW Not cooling #468286
    brett twyman
    thanks for reply. I was hoping that wouldn’t be the case it does get to -17 then warms up again if this changes things i dont know
