Brian Gallagher
Viewing 1 post (of 1 total)
  • in reply to: Hotpoint wdf740puk Belt Problem #466177
    Brian Gallagher
    electrofix wrote:if the old bolt can be removed then it may be possible to fit a new bolt and pulley if its needed
    Thanks Dave, the head has sheared off but there is enough of the bolt to grip onto. Would you advise to use a blow torch to loosen the threads (they seem solid) and then reapply loctite when installing the new bolt?
