Cane 32
ParticipantRe: Hotpoint td32p Condenser dryer
Hi iadom,jim,
Just like to say thank you to you both for the infor regarding the problem with my condensing dryer. After ordering the part and fitting it, we are back up and running again and my wife is delighted.
Would also like to thank UK Whitegoods for the prompt service with dispatching the spare required.
I will be using you again and shall be telling my friends about the service you provide.
Thanks again Cane32. 😀 😀Cane 32
Hi iadom,
Thanks for the reply regarding which part No i need for the relay,but before i purchase the part.I tryed the machine again after twelve hours and it started up, it warmed up started normal spin then into reverse then stopped after about 2mins. Is it still the relay causing the problem or is there a stat that i have missed.
Thanks Again for yours and every ones time. 🙂Cane 32
Hi Jim the model is a Hotpoint Aquarius Condenser dryer TDC32 what part No do i need for the relay, could you tell me what the relay does in operation of the machine too stop it from working when it was working o.k. Thanks for the help. 😀
