charles crellin
ParticipantAbsolutely true, using a fridge thermometer it is getting down to around 5, which is within range for mine and my sons insulin storage, plus good for the milk and food.
charles crellin
ParticipantThink I got it now thank you for your help, the fridge thermostat has no electrical connection to the thermostat PCB, so no matter how much I adjust it it wont bring on the compressor or fan. so it is not a fault, it is how it is made.
charles crellin
ParticipantThank you, will start pulling it apart give it a good check over, I think at the worst it will be a new damper or very worse a new board, thanks for getting back to me and the help, very much appreciated.
charles crellin
ParticipantTrying to upload a picture of the plate but it will not let me, thanks for getting back to me, I fear you are right it is a sensor refrigerator, I can tell you a bit of the problem though, the control inside the fridge its self, when i turn the temperature higher nothing happens, it doesn’t kick the compressor in or the fan when I close the door, the freezer control, if I turn that up higher, that seems to work, it is a new one to me, its something I had to grab quickly.
