Charlie_theCat
ParticipantRe: Indesit W93 4 flashes and clicks round
I can’t see the Rule to which you refer.
sorry you feel that way Smartin. I was looking for some knowledgeable assistance, not just “bin-it” or “Buy a new one”. Some bloke down the pub who saw Elvis could say that! Its not at all helpful to me or anyone reading this in the future.
The forums I regularly participate in others and myself are only too happy to assist others members whether the query is silly or most technical. My trade isn’t washing machines but I do have a good electrical/mechanical background to draw on.
If anyone can help me it would be appreciated- money is tight and £250-300 for a new machine say a Bosch in not on the cards at the moment for reasons I’m not discussing here.
Charlie_theCat
ParticipantOK thanks – I’ll go to the tip later but in the meantime…………
does anyone know the wiring for the pressure switch?
there are 4 wires – blue black brown and red.
I assumed the red was the signal back to the circuit board, but there is no connection to any of the other 3 whether there is pressure in pipe or not. I’m assuming this is not right!!
Charlie_theCat
I did say in my first post the board had been repalced, with a new eprom too. It was a recon board from a reputable company, as reputable as I could determine anyway 🙂
hth
Charlie_theCat
recon – £50. worth a shot when money is tight. 😕 I’m not going to throw good money after bad bot I hate wasting things that can be fixed……..
Charlie_theCat
The connectors have all been cleaned with electrical contact cleaner spray.
The original board had a Fault Code 1 so I changed it – now code 4 appears. as the machine could not show both 1 and 4 at the same time I would suspect, correct me if i am wrong, the code 4 was already present but obscured by the present code 1.
whats your reckoning?
Charlie_theCat
There is a very good chance trhe main PCB is faulty
New board fitted – will check pressure switch though. Simple on/off I assume. can I suck/blow the pipe and use a electrical test meter?
