Thanks I didn’t post model numbers as im getting the same problem with different machines, some work some don’t with the same number.
i checked the plastic condenser tank when changing the heater and looked ok.
its strange because if you watch the cycle the clothes separate like they are drying but when the cycle is finished they are stuck together soaking wet but no water in the drum
