chris knights
ParticipantRe: hoover hd vision 1200 timesaver mode
KWATT i love you 😀
i got a new element for that link you posted , just fitted and put on wash and im over the moon , it works and it was the element , my misses will stop nagging now , cheers for all your help im a happy guy now , and will spread the word about the forum , top markschris knights
update
i have taken the pump out to have a look and all the pipes are clean and clear the pump spins freely and replaced all back and put on a wash as it didnt work , timer saver again , i dont get paid till tuesday , would you say its worth getting a new element as stated it does suffer a earth leak tricking the control panel to come up with a drain error ??
chris knights
you guys have been so helpfull and very greatfull for quick to answer back , i will get the pump off to see if its blocked plus check the pipes to see if any of them are blocked :tright:
chris knights
once it stops half way through a wash and it flashes 3 times on time saver , i have checked the heating element and it works , also change the controlpanel thinking it was a programme problem and still having the same problem
chris knights
sorry been busy with work the model number is VHD 822/1-80
