Chris w
  • in reply to: Bosch washing machine drawer water feed blocked #463195
    Chris w
    Thanks Dave.
    This time, I shall make sure the hoses and ducts are cleared as well as the drawer itself. Then the repair should last a fair bit longer.
    Thanks again for your help.
    Chris
    in reply to: Water reservoir not fully emptying #462618
    Chris w
    Thanks Dave. There is a channel inside the machine from the filters at the front of the dryer to the reservoir at the back – which, I guess is equivalent to the pump hose .
    I’ve blasted water through it with a Karcher and a great deal of gunk came out. This was a bit drastic but it was the only way I could clear it – and it looks like it has worked.
    Hopefully this will have been the cause of the problem and I’ll run a test cycle later today.
    Thanks very much for your help.
    Chris
