Cold chips
  • in reply to: Indesit Forno oven not working but grill heating? #349601
    Cold chips
    Re: Indesit Forno oven not working but grill heating?
    Just ordered it i’ll let you know how it goes.
    cheers for the replys
    in reply to: Indesit Forno oven not working but grill heating? #349599
    Cold chips
    it might be easier with a pic
    http://i275.photobucket.com/albums/jj29 … 8/oven.jpg
    The brown wires in the top right go to a small white component (thermostat cut out?) its not burnt but around it is brown is this normal?
    if the white wires do go to another element and its o/c when tested is this likely to be the fault -top element grill which works, back element oven??
    in reply to: Indesit Forno oven not working but grill heating? #349598
    Cold chips
    Ive isolated the oven (once bitten twice shy!)and removed the back, the the two black wires going to the top element give a reading of 23.7 ohms, there are two white wires going to what looks like another element above the fan these are O/C when tested, does the oven have two elements?
