cold-dinner
  • in reply to: BEKO ECO WMB 81445 #450839
    cold-dinner
    Re: BEKO ECO WMB 81445
    Hi, would this also apply to a WMB 91442LW? I’m having exactly the same problems. I can’t see any brushes on the motor. Error code F13 / 0417. From what I’ve been reading, it seems I’ll have to buy a new machine. Thanks
    in reply to: worcester bosch combi boiler #256377
    cold-dinner
    Re: worcester bosch combi boiler
    thank you phidom, the pressure info was helpful. I’ve now deduced that I need to replace the auto air vent, which is for the central heating side. the reason there was no hot water is that the leaked water got into the air pressure switch, which shut the boiler down. Reading through forums on the subject, it seems quite common for these auto air valves to leak, but it looks easy enough to remedy. Regards, Tracey
    in reply to: worcester bosch combi boiler #256375
    cold-dinner
    thank you Dave, I’ll try that.
    My name is cold-dinner because I also have a problem with my cooker! :rolls:
