Dan Kelly
Viewing 1 post (of 1 total)
  • in reply to: AEG D81000m #319455
    Dan Kelly
    Re: AEG D81000m
    MarkJF wrote:I had an issue with the lower oven switching off. Traced to the on off switch. It is just dirty contacts – I fixed it with Maplin Contact Cleaner spray – only needed to remove the top inspection panel and did not have to remove the on off switch itself. Total cost to fix about 2.50!
    Cleaner now £3.25. Squirted all openings and operated switch several times.
    Main oven cut just after the warm up beeps. Clock and top oven stayed on.
    Tried main oven again, it’s stayed on for 45mins so far. Will switch off now and try cleaner again when cool.
