March 17, 2016 at 4:25 pm in reply to: Spray Arms not turning at all on Lamona 8670 (Beko make) #436258
danger_mouse
ParticipantRe: Spray Arms not turning at all on Lamona 8670 (Beko make)
Gentlemen,
Thank you for your replies. It was indeed the wiring loom 🙂
March 16, 2016 at 8:01 pm in reply to: Spray Arms not turning at all on Lamona 8670 (Beko make) #436257danger_mouse
Thanks for the feedback. Ill check out the wiring.
I’ve posted a video of it happening https://youtu.be/ttRbb3utJaQ
March 16, 2016 at 6:36 pm in reply to: Spray Arms not turning at all on Lamona 8670 (Beko make) #436253danger_mouse
OK I’ve reattached the diverter valve. I flicked the door latch closed so I could observe the arms. They were still not turning UNTIL …
I pulled the door wide open!!
As soon as I opened the door wide open the arms started spinning. Close the door a little and the arms stopped. At least the pumps are working fine but can someone please shed light on what is causing the problem?
March 16, 2016 at 2:12 pm in reply to: Spray Arms not turning at all on Lamona 8670 (Beko make) #436251danger_mouse
Quick update:- just tested the motor quickly and it turns fine.
March 16, 2016 at 2:03 pm in reply to: Spray Arms not turning at all on Lamona 8670 (Beko make) #436249danger_mouse
Thank you K.
No, live testing is not an option really especially given it’s location underneath the dishwasher and your comment about danger is understood.
I’m going to manually put the valve in the position to supply the arms, refit to the machine and that way if the valve does not move then it is likely to be this part that is faulty. If the valve rotates then it could be the stage before which tells the valve to supply water to the arms.
If the valve is not getting 240v to switch the water to the arms, can someone please tell me what might be stopping it? For example, will the dishwasher check first that the water is at the correct temperature/level or is it simply at minute X of the wash cycle spin the arms? Something else?
March 16, 2016 at 1:15 pm in reply to: Spray Arms not turning at all on Lamona 8670 (Beko make) #436247danger_mouse
Thanks K,
That is the part. I’ve now taken it off. It was clean and no obstruction. I’ve manually turned the disc valve between the two openings and one position makes it open circuit and closed in the other.
I’m getting 13 ohms across the motor terminals. What else is there to test? Can I simply put 240v to the motor to see if it will turn?
Richard
March 16, 2016 at 12:46 pm in reply to: Spray Arms not turning at all on Lamona 8670 (Beko make) #436245danger_mouse
Hi Dave,
Thanks for quick response. The filters and arms are clean (and weren’t too bad anyway). It fills with water to just below the door level so looks good.
I have taken the bottom off now and am going to take the diverter off to see if any obstruction. Failing that what’s the best way of troubleshooting the exact problem?
Richard -
