dangerous brain
  • in reply to: Hotpoint ultima washing machine #298925
    dangerous brain
    Re: Hotpoint ultima washing machine
    OK well I will have to fail to understand why a switch doesn’t alter its continuity when operated lol. So does anybody know where abouts I could get a mainboard for this machine thats not going to tear my wallet in half (like I said its not even my machine) or if its ok to just solder in replacement bits like the transistor and transformer thats gone?
    in reply to: Hotpoint ultima washing machine #298923
    dangerous brain
    helo_75 wrote:it has a live.. a neutral and a common
    door closes, switch is activated, door locks.. feed supplied to board
    I gathered it would do something like that, but I failed to find a difference in continuity across any of the 3 pins when operating manually the door shut part of the switch which I would expect to find as I’d expect the mainboard needs to know the door is shut before it tells the lock to operate.
    in reply to: Hotpoint ultima washing machine #298921
    dangerous brain
    helo_75 wrote:itll be a wma
    the lock wont switch till its ‘locked’
    the neutral on the board will be cooked
    Ah ten points lol!! Its a WMA61.
    I can understand the lock not switching until the lock is depressed but how does it output the signal to say the door is closed?
