danieltrigg4@icloud.com
  • in reply to: Very strange drain issue #489719
    Thanks for your help. From memory the tank is back left a pipe goes from that to the pump and a few come off it and go in various places. I have to have the machine on its head to do the work and it’s fiddly as I just pull the bottom up enough for me to get in and mess around.. yeah I changed just the pump but took the housing off and there was no visible blockages in there. I’ll stick a pipe cleaner down the places I can and see if that helps. A diagram would be brilliant but if you can’t do it no problem. Would a similar model not be the same?
    thanks for your help
    dan
    in reply to: Very strange drain issue #489717
    I’ll have to take it apart again. I think from memory just two pipes on the drain pump though a in and out. I’ll see if there is any other pipes.
    thanks
    in reply to: Very strange drain issue #489715
    Hosé hasn’t been extended, I thought that. Guessing there has to be water around the fins of the pump for it to actually drain otherwise it just spins in free air?
    any other reasons why it would air lock?
    thanks for the reply!
