dave j
  • in reply to: Bosch HBN3550GB doesn’t heat and no fan #181377
    dave j
    Re: Bosch HBN3550GB doesn’t heat and no fan
    gegsy wrote:
    dave j wrote:
    I guess that’s the “make sure they’ve not got the timer on” question. 🙂
    How did you guess 😀 but you would be suprised how many calls we goto that have the clock set to “auto” or not set at all.
    I’ve done IT support in the past and know how frequently things like that can come up. Not plugging things in at the wall was always a good one. 🙂
    You have set the clock havent you, I know you mentioned duration 00.00.
    Yes. The clock’s set. I even got it to run through a start/stop cycle on the timer and that all worked – apart from the heating up bit. 🙁
    If all that is done I would suggest an engineer from the link below.
    OK Thanks for the help.
    dave j
    in reply to: Bosch HBN3550GB doesn’t heat and no fan #181375
    dave j
    There is no hand symbol on the display or mentioned in the manual.
    I have gone through the “turn off the timer” procedure, set the time/duration to 00:00, but that made no difference.
    dave j
