Dave Wishart
ParticipantThanks don. I ordered a WEG665 WCS direct from Miele’s (central) outlet store. Gets delivered next Friday.
September 18, 2020 at 10:35 am in reply to: ISE AW23 Service Manual – Concrete Block and Drainage issue #471998Dave Wishart
Participantiadom wrote:The concrete weights are here..http://shop.ukwhitegoods.co.uk/ise-drum-parts
I usually had to try and source bolts locally.
I don’t need a new concrete weight as it’s still intact it’s just I’ll have to remove and get the old sheared bolt out of the outer drum without damaging it and put a new one in. If I do, replacing the outer drum will be a bit of an arse to fit and not cheap. I’ also not sure if the part on the shop would be an exact fit
September 18, 2020 at 10:26 am in reply to: ISE AW23 Service Manual – Concrete Block and Drainage issue #471997Dave Wishart
Participantiadom wrote:Those pumps all appear to be second hand ,:(
True. It may be that my old pump motor is ok but was prevented by that the bit of ice lolly stick and blocked pipe. I do get your concern over used parts though.
September 18, 2020 at 7:42 am in reply to: ISE AW23 Service Manual – Concrete Block and Drainage issue #471995Dave Wishart
ParticipantThanks for the help all. I found the same part on ebay (sorry shop owners) and fitted last night. All is good and SWMBO is happy.
In dismantling the assembly I found a broken wooden ice lolly stick which probably hasn’t helped. (I did check the filter first but It was jammed in and wasn’t visible then.
September 14, 2020 at 10:46 pm in reply to: ISE AW23 Service Manual – Concrete Block and Drainage issue #471993Dave Wishart
ParticipantThanks for the help this was easier that I thought as I could access the base of the machine with just removing the base panel and not have the faff of the door panel. I found a load of limescale in the drain hose exiting the pump along with some in the pressure sensor tube. After restarting the fill and main wash go ok but then theres a 5 minute pause and I get the E06 code again. Given this is a 60min cycle my guess is that it fails during the drain. I’ve also tried a drain only but that fails. My guess is that the limescale blockage has burnt out the pump.
The unit I have is marked Plaset cod 66129. I had a look in the shop but I’m not seeing any that look right. Then again I’m no expert. Are there any that could work ?
September 14, 2020 at 10:20 am in reply to: ISE AW23 Service Manual – Concrete Block and Drainage issue #471990Dave Wishart
ParticipantYes. It was a combination of the top cover and front panel that I needed to do.
September 14, 2020 at 7:34 am in reply to: ISE AW23 Service Manual – Concrete Block and Drainage issue #471988Dave Wishart
ParticipantI’m assuming, from looking previously this won’t be easy to get to. Is it the the whole of the rear panel that gets removed?
